Found 1987 300D om603 for $360!!
jonbobshinigin
Just picked this up cheap. I have been browsing for a good 3.0 603 to replace my dad's 3.5 rod bender. I figured I would find something one day cheap in a 124 body with other parts I could use too. Found this with 227,500 miles on it. Engine did not run when I got there. Glow plug relay fuse/strip was not connected so start up was not easy. Air was in the fuel system so I bleed it (although it is supposed to be be self bleeding). Also, the ELR (controls idle speed) was set at 2, instead of the default 5 (I think it is).
I got it to start up in 5-6 minutes after using my battery. It doesn't overheat and upper hose was not hard so head appears to be fine, even though it is a #14 head. It does have green coolant though. Transmission shifted ok, although there is a vacuum leak somewhere and the fluid needs to be changed. When I got it home, it sat overnight and I tried cranking it in the morning but it did not work. Checked fuel stuff with no luck, but then bridged the glow plug fuse strip and it cranked immediately. Engine has a slight tick, which is how my wagon was until I swapped to synthetic oil. My guess is the lifters.
The car was a Michigan car so it is a rust bucket. Interior is great though so it must have been mostly highway miles in it's early days. It is also the uncommon black interior. My plans is to get the engine and transmission up to snuff and then pull them and clean them and replace seals and have it sitting ready for an install somewhere else. And I MAY put this transmission in my wagon, while I save up to have my original rebuilt for my power. I will gut everything else and sell what I can. The interior should pay for the car!
Here is a video, let me know if you have any problems viewing. if so i can upload it to youtube:
http://www.godspeed22.com/benz/1987300d.mov
1987 300TDT - 185,000ish
>>275HP om603 Project Profile here<<
1981 300D N/A - 250,000 (Project Car)
| 09-03-2010 01:24 PM |
