Dual Swaybars
Dual Swaybars
http://forums.turbobricks.com/showthread.php?t=9587
I'm thinking of trying out duals on the rear. It would help in getting the car to not understeer as much, and I don't think the difference would be enough to send it into oversteer. Seems like some threaded rod, some pipe (spacers) and simple adapters at the ends would be enough to set it up.
For comparison's sake, is there an aftermarket swaybar option for our cars? Cost? I'm thinking that stock 240D rear swaybars can't be commanding a premium price. I figure this mod could be done for maybe forty bucks and on a Saturday. Possibly less.
The front I think will be left alone until I decide to rent a spring compressor and fire up the grinder. I think the cut springs in front and duals in the back with fresh shocks should be a decent setup. Possibly 2 coils in front with one in back. I'll have to see.
09-30-2009 01:43 AM
RE: Dual Swaybars
There is no aftermarket. We talked about metal zip tying some sways together for the lemons race and never got around to it. You *can* get a customer sway bar made for probably around $300 from a local spring shop.
09-30-2009 02:04 PM
RE: Dual Swaybars
Are there any differences on the stiffness of the sway bars between a 240d 300d or 300td???? would be nice to just upgrade to a better stock one!
09-30-2009 06:41 PM
RE: Dual Swaybars
Nope. Only option was the 15mm used on SLS vehciles with the extra heavy duty option and all of those are NLA after a rash of sales after I purchased mine.
10-01-2009 01:24 PM
RE: Dual Swaybars
(09-30-2009 06:41 PM)willbhere4u Wrote:  Are there any differences on the stiffness of the sway bars between a 240d 300d or 300td???? would be nice to just upgrade to a better stock one!
Is there any objections to narrowing a W126 17mm rear sway bar? The plan.. I am going to cut out a section in the middle of the w126 swaybar. Then slide a 4 inch sleeve on, weld back the sway bar together, then slide the sleeve over the welded area and then seal the sleeve with a bead of weld. Hopefully I won't F-up the metallurgy of the bar and have it crack during hard corning.
(This post was last modified: 10-02-2009 06:32 PM by DeliveryValve.)
10-02-2009 06:31 PM
RE: Dual Swaybars
No objections. Try it out - worst comes to worse, you'll have wasted your time and a junkyard swaybar. If it works, then it's another option for the W123 owner.
10-02-2009 10:51 PM
RE: Dual Swaybars
(10-02-2009 06:31 PM)DeliveryValve Wrote:  ...
Is there any objections to narrowing a W126 17mm rear sway bar? ....
OK, I don't know where I got this notion of a w126 17mm rear swaybar ever existed!
I've been to a couple of PNPs and I am now convinced that the w126 only came with, at my estimate, a 14mm rear sway bar. Not worth the trouble to modify.
I did however find a swaybar that might work with some modifications.
I pulled this rear sway bar from a W116 1974 450SEL. Too bad this car was in the yard, but you Gotta love California cars. This fine example is rust free and clean up looking like it was almost off the assembly line for being 35 years old.
And the great thing about it....... It is a whopping 18.5 mm! Compared to the w123's toothpick diameter 13mm swaybar.
Of course some modifications will have to be done for it to work. Luckily there was a w123 at the yard to compare and size up.
The first thing would be to heat up the side bars and bend them 180 degrees the other direction. The side bars are flat so this should be doable. I have to rearrange this because the w116 swaybar has a bend that will interfere with the differential. Other things to note is the side bars would also have to be shortened and re-drilled for use with the w116 style metal swaybar links. Which by the way is much stronger than the w123's plastic links. The body mounting position is I believe right on with the w123s. The only other problem will be the bend in the center of the bar might hit the spare tire wheel well after doing the side bar mod.
I'll make another thread to discuss this bar after I get around to installing it.
(This post was last modified: 10-10-2009 04:24 PM by DeliveryValve.)
10-10-2009 04:17 PM
RE: Dual Swaybars
BTDT I'll be interested to see if you have diff results. 17mm 126 bars are found on SEC and SLS.
10-10-2009 05:20 PM
RE: Dual Swaybars
Cool, DV, let us know how this goes...
I'm debating whether to do this first or get shocks first. My shocks suck. However, I think I'd be able to do this mod 4 or 5 times over before I reached the cost of a new set of HDs.
Now that I've gotten to drive the car in a semi normal mode (working PS and axles that don't have to turn 90 degrees before catching), the understeer is less of a problem than I at first thought, but it's still there. I'm wondering how this thing will be pegged on the highway with a stiffer bar...however there's plenty of places to test where I live and I might have it set up to be 'adjustable', ie you can connect or disconnect the rear bar without much trouble. Should be easy, some anti seize and wingnuts should do the job, and a way to make sure the bar doesn't dip and catch on something.
Speaking of adjustment, you might have room on that bar to add a couple of holes for adjustment positions on that 116 bar - toward the pivot point should be stiffer.
Don't forget that Moog makes steel replacement end links for our rear swaybars. About 30 bucks a pair.
10-10-2009 05:21 PM
RE: Dual Swaybars
(10-10-2009 05:20 PM)winmutt Wrote:  BTDT I'll be interested to see if you have diff results. 17mm 126 bars are found on SEC and SLS.
Been there done that? You mean with a w116 sway bar?
I was looking at an '83 SEC non SLS and there was just the 14mm sway bar. So I guess the SLS option would have it.
(10-10-2009 05:21 PM)CID Vicious Wrote:  ...
Good idea and I'll check on the Moog part.
(This post was last modified: 10-10-2009 07:31 PM by DeliveryValve.)
10-10-2009 07:29 PM
charmalu Offline
RE: Dual Swaybars
There is a 560SEL Euro with SLS at one of the PNP. think I will swing by there and check the rear sway bar with my Caliper.
Charlie
10-11-2009 12:09 AM
RE: Dual Swaybars
If you want to stiffen up a swaybar, simply shorten the side arms. Shift the mount point further back so the bar has more leverage.
10-11-2009 04:57 PM
charmalu Offline
RE: Dual Swaybars
Well I measured the bar on the 85 500SEl Euro with SLS, and it shows about 17.25mm.
right behind it was another 85 500SEL but U.S. spect. that bar measures 14.25mm.
these two looked like twins, blk on blk.
I now own a larger sway bar. where the W116 is curved, the W126 is straight,
Charlie
10-11-2009 08:03 PM
RE: Dual Swaybars
(10-11-2009 08:03 PM)charmalu Wrote:  Well I measured the bar on the 85 500SEl Euro with SLS, and it shows about 17.25mm.
Charlie
Charlie, could you take some pictures of the bar and post them?
The w116 bar measures 45 inches between the two mounting bushings (starting and ending at the welded rings) . I like to know what the 126 bar measures.
(This post was last modified: 10-11-2009 08:45 PM by DeliveryValve.)
10-11-2009 08:39 PM
RE: Dual Swaybars
(10-11-2009 04:57 PM)Kiwibacon Wrote:  If you want to stiffen up a swaybar, simply shorten the side arms. Shift the mount point further back so the bar has more leverage.
Yeah, but in our case we'll just end up with a slightly stiffer coat hanger.
Most of the adjustable bars have three holes on either side about an inch or two away from each other. Moving towards the pivot will stiffen the bar, but the adjustable bars tend to be large and offered as a stand alone product instead of part of a concerted system. If the car is too hairy with the bar on the street, but you like it at the track, you can just move the attachment point and wa-la.
Maybe with a set of adjustable endlinks you could see a significant improvement, but I'd guess that with a stock bar you'd have to move it further back than would be practical. Somehow, stiffening a stock bar like that is like expecting 'extra stopping power' from the mod you just did to your BB gun...it might be there, it might even be measurable, but it's probably not the result you're looking for. However, do try it and let us know.
I posted this because the Volvo guys are kind of in the same boat as we are - people mod those cars but not so much in this market, so they have to get creative instead of letting the Visa card do the heavy lifting. However, those SOBs have IPD sway bars and whatnot, but this has apparently been tried and it works, it's not hard to accomplish and requires no cutting or welding of the car. Basically, stack of washers (ok, if you want a pipe spacer you might have to whip out the hacksaw), threaded rod of the appropriate type, and a junkyard sway bar with related hardware. I'm thinking that steel strap would work to connect the 'new' bar to the one already in place, might have to drill four holes. No special equipment or parts necessary - anyone anywhere with one of these cars and a place to get used parts can do this.
I think this mod in the rear (I can't see doing the front, too, but maybe), combined with some judiciously cut coils and some HDs would make for quite a willing back road bomber. Well, that and some friggin' tires that don't seem more at home on a Civic...honestly, 185's, and stock spec was for 175's? Next after the above is accomplished I'm going to look into getting a parts 300SD so I can cannibalize damn near everything off of it - motor, wheels and tires, brakes.
I don't know, though. Maybe I'm better off just keeping the 240D stock and looking elsewhere for a road toy. I'll have to crunch the numbers and see, if it reaches 1500 bones then I could theoretically buy back my Civic for what I sold it for to get this. I know, I know, but hey...that car was a fucking blast to drive and it wasn't even very well set up. For the money, if you're willing to turn a wrench it's the best way to get something you can just drive the snot out of. I'd love to get my hands on a CRX. Even a joe Civic breathed on just right. Wait in the shadows for some sap who's got kids now and his wife wants something 'safe'. Or just do something else with what little time I have left on Planet Earth (no matter how much time that may be)...
10-11-2009 09:02 PM
RE: Dual Swaybars
Have you guys approached custom spring makers?
Afterall, a sway bar is just a double ended torsion spring. They should have suitable material and forming gear to custom make them.
10-12-2009 12:38 AM
RE: Dual Swaybars
(10-12-2009 12:38 AM)Kiwibacon Wrote:  Have you guys approached custom spring makers?
No I personally haven't.... I am a cheap mug. I got the w116 bar for 20 bucks. Definitely worth trying to modify.
(This post was last modified: 10-12-2009 09:24 AM by DeliveryValve.)
10-12-2009 09:23 AM
RE: Dual Swaybars
I heard ~$400 for a custom one. Would love a 17mm or a hollow one.
10-12-2009 01:05 PM
RE: Dual Swaybars
We could get a group buy going and that would bring the price down, but you're still talking 200 bucks, I would think, and we'd likely have to get other enthusiasts (Benz Forum?) to chip in, as I can't see more than maybe 10 folks from here ponying up that for a new bar.
Unfortunately, our cars are so niche and a rare choice for tuning, so the economies of scale don't apply so much. The potential market is huge - how many 123s did they make? - but the car doesn't get looked at in the same way as, say, a Camaro, or another car with a huge following that people buy because they like to drive.
Sadly, if people were to get wise to these cars, they'd probably become more expensive to buy. Might be great for some of y'all with 2 or 3 kicking around, though...
10-12-2009 01:50 PM
charmalu Offline
RE: Dual Swaybars
This is a rear sway bar off a 85 500SEL Euro with SLS. measured 17.25mm
there was another 85 500SEL. (DOT Approved) the sway bar on it is 14.25mm
Charlie
(This post was last modified: 10-16-2009 11:58 PM by charmalu.)
10-16-2009 11:55 PM
RE: Dual Swaybars
~2mm wider than the stock ones right?
10-19-2009 10:08 AM
fha772 Offline
RE: Dual Swaybars
What does a stock W123 sway bar measure?
How much bigger is the W126 bar?
[Image: CUNNINGPLAN1STDRAFT-1.jpg]
08-17-2011 01:16 PM
RE: Dual Swaybars
W123 is 13.5
W126 can be found in 15, and 17, and even torsion bars. They are about 2cm too wide however.
08-17-2011 02:20 PM
fha772 Offline
RE: Dual Swaybars
Is that 2cm too wide at the ends or the actual bar length?
Could the ends be bent in by 1 cm each to fit?
08-17-2011 02:27 PM
iheartboost Offline
RE: Dual Swaybars
Man...thats some pathetic rear sway diameters. I might have to try and fab one up.
1987 300d - project undecided which direction its going in.
2008 chevy cobalt - DD + Autocross car
08-17-2011 04:36 PM
