Cold compression data worth anything?
cell
Over the holiday break I reamed and replaced my glow plugs, and performed a compression test while I had the fuel lines off.
Unfortunately, this was before I was aware that you are supposed to do the compression test with the engine warm. I plan on redoing the test, but I thought I would ask if there is any value in the cold numbers.
The results were: 330 to 340 for cylinders 1,2,4 and 290 for cylinder 3. After doing some more reading it seems 290 is marginal. The harbor freight 90 degree fitting broke on cylinder 5, so I have no data for that one.
| 01-05-2010 02:59 PM |
RE: Cold compression data worth anything?
Cold numbers are more useful. Warm numbers are artificially high from the tighter clearances and won't give any insight into how well it will start in cold weather. 330psi cold is good.
| 01-05-2010 08:42 PM |
cell
(01-05-2010 08:42 PM)ForcedInduction Wrote: Cold numbers are more useful. Warm numbers are artificially high from the tighter clearances and won't give any insight into how well it will start in cold weather. 330psi cold is good.
interesting, thanks!
| 01-08-2010 12:57 PM |
Great info, thanks for checking!
| 01-25-2010 01:36 AM |
