kamel
Naturally-aspirated SUCKS
RE: '83 300D
Pics?
| 05-18-2009 07:40 PM |
SurfRodder
RE: '83 300D
(05-18-2009 06:55 AM)winmutt Wrote: When you do the springs replace the LCA bearing and LCA strut rod bushing. Use the 3 piece LCA bearing from the 126, it will last longer than the 2 piece found on the 123 normally.
thanks for the tip, I already bought the 2 piece style, but if the others are that much better Ill get them instead... the only really sucky part is that this weekend I installed the 123 ones in the arms and threw away the boxes to consolidate space and see what I still have left to buy for the swap... Ill have to look at the cost/benefit tradeoff and go from there... these ones lasted 245K but we'll see... If i find poly bushings for the 126, that might make the difference...
(05-18-2009 06:55 AM)kamel Wrote: Pics?
I'll see what I can drum up... I have a bunch of pics from my auto to manual climate control conversion...eventually will have a writeup, but too lazy/busy to do it right now... I should take some pics under the hood of my Earl's plumbing... Once I finish the aforementioned suspension/brake upgrade, I will take pics of the exterior... it needs a bit of work, prolly a good scrape and buff but the body is in otherwise good shape, just would rather take pics with the new stance and wheels installed.
'83 300D **4 speed ** stainless flex oil cooler and brake lines ** powder coated valve cover, oil tower, and injection lines ** manual climate control ** better stereo ** homemade intake and monstercraftsman oil separator ** EGR Delete ** Euros headlights ** 4 brake light mod ** Vogtland 50mm drop front springs ** Lesjofors S600 drop rear springs ** 16" rims ** late model 126 brake spindles, rotors and calipers ** full suspension rehab ** Bilstein HDs ** AL129X alternator ** 1/0 starter and charging cables ** late W126 front seats and rear seat back ** 300GD Clutch and Flywheel **
In progress: ported head, VGT ,W115 intake and exhaust fueled by MW pump with Tomnik's 6.5mm elements ** projector HID retrofit into euro style H/L housings
OBK# 62
| 05-26-2009 11:40 AM |
SurfRodder
RE: '83 300D
OBK# 62
| 06-15-2009 05:07 AM |
SurfRodder
RE: '83 300D
(08-06-2009 12:01 PM)winmutt Wrote: Need to take a coil off the fron there, what pads are you using front and back? 1 and 3?
yeah 1 and 3, I probably wont take any more off the front, I like where it sits right now (loads better than stock) and as it is I'm getting a little rubbing on the tires... I'm assuming its happening when I throw her into the corner, but I'm not positive as I dont get any feedback indicating that. stopped and at full lock there is still plenty of clearance for me to run my hand completely around the tire on all sides, but I'm getting a slight 'trim' on the outside edge of the tire. I think maybe I'll have to roll the fenders at some point, but right now it doesnt appear to be too drastic.
OBK# 62
| 08-06-2009 12:10 PM |
SurfRodder
RE: '83 300D
So, my Pappy backed into my car the other weekend and smashed my grill insert...
thus forcing me to buy a new one. While I was at it, I changed it to the 'sport' style found on fleabay. I took a chance and actually like the way it looks, esp. with the euros. I was going to switch the clear corners back the the stock amber ones, but may not with this new grill. Still missing is the MB emblem below the hood ornament...gotta snag another one next time I hit the part yard.
unfortunately, I also have to get a replacement aux. fan as the one that is in there now is unplugged because the aluminum bracket is also now cracked. sucks major, because I just installed that one new about a year ago... gonna hit the yard for a replacement tho... not going to shell out another 200 bux for a replacement.
OBK# 62
| 08-31-2009 01:10 AM |
RE: '83 300D
I'd keep the cracked grill on instead of a "sport" grille.
| 08-31-2009 02:31 AM |
SurfRodder
RE: '83 300D
(08-31-2009 02:31 AM)ForcedInduction Wrote: I'd keep the cracked grill on instead of a "sport" grille.
winmutt Wrote:I dont really care for the sport grill myself either. I do like the blacked out grill look.
I def. like the blacked out grill and I dont mind the sport grill so much, but the dueling tri-stars is off-putting, I may pull another insert from a junker and mess with it until I get something I like better. Perhaps something similar to MB TECH's wagon.
Anyway, here's the new pics of the ride, also posted on the SLS removal thread:
I like the slight rake it has now, It will probably settle out a little in the next few days, but I think it will still retain a bit.
Heres a pic showing the drastic difference between the way it was above and the way it sits now... it no longer looks like its dragging nuts across the road.
I think now that most of the mechanical issues are ironed out, I will start keeping an eye out for some darker interior, I'm not a big fan of the parchment color and most of mine is trashed anyway. I think I will call MBCA about one of those taxi dashes too, with the better real estate for gages and a better center vent setup for my manual climate system. Now I gotta do a better job of keeping her clean, sucks not having a garage tho. Hopefully after I find out about my scholarship I will buy a house and have a place to keep her out of the rough San Diego weather.
OBK# 62
(This post was last modified: 09-11-2009 07:26 PM by SurfRodder.)
| 09-11-2009 07:19 PM |
SurfRodder
RE: '83 300D
(09-11-2009 10:04 PM)garage Wrote: Surfrodder, that sure is a great looking clean w123.
I like those wheels, and actually really like the grill upgrade..yes upgrade=]
I dunno about *clean*, but it shows okay in pics...  (actually you can see where a bird dialed me up on the back bumper moulding) I really need to detail it, but I don't have the time right now and as posted above I dont have a garage to keep the dew and dust off of it so I dont wanna spend all the time to have to do it again in a few weeks. Anyway, thanks for the compliments.
OBK# 62
(This post was last modified: 09-11-2009 10:09 PM by SurfRodder.)
| 09-11-2009 10:08 PM |
SurfRodder
RE: '83 300D
(09-14-2010 11:21 PM)stan Wrote: why all the funky stuff? i got mine in with the stock bolt and bracket, and with a stock size belt with no problems.
Im guessing that you either dont have an AL129X and/or perhaps your adjuster bolt was already shorter than mine. My first take on it I trimmed the hell out of the bracket and then realized all I had to do was shorten the bolt. at any rate I there was definitely not enough slack in the stock belt to get it to work on my car.
(09-14-2010 11:10 PM)garage Wrote: The w126 rear seatback will fit in a w123??
If so i really wanna pick up a nice one at the yard tomorrow..or asap.
yeah, itll fit. Whenever I see something that looks close, I try it out in the part yard to see. Its a little tight, doorskins are up against it, and depending on the generation the top is a bit of a PITA to attach at the package tray, but I think itll look good once I get around to making a custom insert for the package tray, my intention is to utilize most of a 126 one with the speaker mounts and 3rd brake light.
Anyway, I'd definitely check it out on a yard car so you can see what the issues are for yourself.
OBK# 62
(This post was last modified: 10-12-2011 12:20 AM by SurfRodder.)
| 10-12-2011 12:17 AM |
mike-81-240d
more like mike-84-300d now
RE: '83 300D
1984 Kalifornia Emissions 300D turbo Silver blue metallic on blue MB-Tex
Current mods: 3rd brake lamp, 4 brake mod, dark amber euro corners, euro tails, vacuum euro low specs, straight piped+glasspack, slant cut tip, boost at 10 psi, 16x7 polished CLK's, oem skid plate+protection plate , 12in sub , kenwood HU, Hella 500's, roof rack+custom wind fairing, 55 watt 4500k bi xenons, EGR delete, ARV delete.
Future mods: MBC, tune stock pump, cut springs, euro bumpers, manny tranny, Hy35, 10mm elements
| 11-07-2011 02:55 AM |
